shock spacer/mounti...
[Closed] shock spacer/mounting, any reason i can't run these instead ?
The lads Sworks Enduro comes with these
[img] [/img] In the frame end of the mountings.
Any reason i can't use this type instead ?
The overall width is 21.8mm which they make a kit in at TFTuned... So i can't think of any logical reason why not ?
There is a reason/logic behind this... As you may have seen in other threads, we do a fair bit of shock swapping, changing, fiddling and trying etc. The spacers at the top are VERY VERY hard to remove and the only technique i've got is a pair of pliers/grips, which have not exactly been kind to them. We're debating which shock to run in his bike for upcoming races we've got and would be nice if i can take the 3 shocks out and run them back to back, if i've got spacers/eyelet stuff sorted i can swap the shock in less than 2 mins. But with needing to swap the mounting hardware you're looking at 10 mins and the potential for dropping a part on the trail and losing it.
So, can i run the usual shock mounting instead of the metal spacers ?
Posted : 20/06/2021 11:02 am
forum seems to be being a bit daft so trying a 2nd post.
Posted : 20/06/2021 11:03 am
Yes, and its normally worth upgrading to the second style, the first type are pretty old school now.
Posted : 20/06/2021 11:25 am
Excellent, thanks matey. I'll get a spare set ordered up from TFTuned
Posted : 20/06/2021 11:29 am
In theory it should work, both the spare Ohlins and Rockshox we bought have the upgrade kits in the box with them.
The good thing with TF is that a quick chat on the phone with them and they will tell you exactly what to order.
I did that with the one we bought from you and it was with us next day
Posted : 20/06/2021 11:49 am
It's a big improvement imo, those originals are a royal pita, I've even replaced them on new frames before building the bike up, along with binning DU bushes for poly ones.
Posted : 20/06/2021 10:33 pm
