Shock mount hardwar...
Shock mount hardware - bearings vs bushings
7 Users
4 Reactions
 mr_p
I'm looking at replacement shocks on eBay & pinkbike and some have bearings for the lower mount whereas my current shock is fitted with the usual DU bushing + top-hat spacers (20mm width I think) plus a couple more spacers on each side (the bike is a YT Jeffsy from about 2018)
Are these mounting types interchangeable provided the width is correct or do the bearing mount ones only go into certain frame designs?
Posted : 25/10/2023 11:30 am
 mc
Define bearing mount?
Trunnion mount shocks, which have a bolt hole either side of the body, will most definitely not fit in place of a conventional eyelet mount shock.
However there are a few different eyelet type bearing mounts, which may or may not fit, so it would probably be best if you could post some links to what you're looking at.
Posted : 25/10/2023 11:37 am
Yeah my Slayer had a bearing mount but was an insert into a 'normal' eyelet with the bearing mounted inside the insert. Things like the Super Deluxe you often see, won't fit non-specific frames.
Posted : 25/10/2023 11:39 am
 mr_p
Yeah not a trunion top mount, just the bottom eyelet has different mountings on different listings such as this example below
https://www.pinkbike.com/buysell/3627029/
Posted : 25/10/2023 11:48 am
yeah.... that's a no.
Posted : 25/10/2023 11:50 am
The rs ones are specific but you can get pressfit bearings (fox among others iirc) which could also be used on an rs shock so it's not a simple answer - when is it ever?
In the case of that shock, no it's not easily swapped.
Posted : 25/10/2023 12:02 pm
 mr_p
Ok thanks, I give up with all the different standards. I think the only solution is a new bike!
Posted : 25/10/2023 12:27 pm
thols2, ThePinkster, ThePinkster and 1 people reacted
You need 30mm spacing to run bearing mount, Rockshox now do a kit similar to Fox's version that goes in standard eyelet but aren't compatible with some air shocks.
Posted : 25/10/2023 2:56 pm
 mr_p
The actual spacing on mine is 40mm it seems, 20mm for the eyelet bushing/tophat then 10mm metal spacer each side, so do you reckon something like the below would make it fit?
https://j-techsuspension.co.uk/products/rock-shox-deluxe-super-deluxe-mounting-hardware-40mm-bearing-dust-cover?variant=43012794155259
Posted : 25/10/2023 4:49 pm
That would work for the shock in your previous but only the bearing end obviously.
Posted : 25/10/2023 4:58 pm
I didn't even know they existed, looks like you can buy a bearing mount shock and just pop those adapters on, if your shock bolt is 8mm.
Posted : 25/10/2023 6:10 pm
Think to remember is if your shock only rotates a degree or two at one end, you're better off with a bushing than a bearing. I'd say you need to be getting towards 90 degrees before the bearing mounts are helpful.
I used to run a RWC roller bearing in the DHX5.0c on my turner 6 pack, but only on the top bearing.
Posted : 25/10/2023 6:52 pm
Looks like those spacers would fit, on a 30mm mount there are just bearing covers each side that must only be about 1 or 2 mm thick
Posted : 25/10/2023 6:57 pm
