Anyone else had vibrations from a Zee rear brake?
Swapped from XT's to Zees for a bit more power and the rear is vibrating just as it starts to get hot.
When it gets propper hot the vibration goes away again until i stop and it cools down.
Everything else in my setup is the same as when I had XT's on.
Swapped pads and rotors front to rear/ rear to front and the problem stays at the rear.
Also tried metal and resin pads with no difference.
All ideas welcome.
Posted : 28/06/2015 4:41 pm
Rear wheel bearings worn or rear axle/qr loose?
Posted : 28/06/2015 5:44 pm
King hub with bearings adjusted spot on and 142 axle nice and tight.
Posted : 28/06/2015 11:13 pm
something wrong in the calliper then?
Posted : 28/06/2015 11:35 pm
That's what I'm thinking.
Next plan is the swap front and rear calipers round.
Any more ideas?
Posted : 29/06/2015 8:47 am
