So when I'm on my big cog on the back and I want to shift down, if the clutch mech is on it won't drop down. If the clutch mech is off it shifts spot on. In the on position it is also a little more resistant on shifting up. Anyone had similar problem?
Posted : 09/01/2017 2:20 pm
Assuming it's indexed correctly, give it a bit more on the B-tension screw. If that doesn't work try a bit less. If neither of those work check the mech hanger is straight. Then that the cable isn't poor. Same as for any other drivetrain really.
Posted : 09/01/2017 2:42 pm
Mine is like that on an 11-46. sublime without the clutch and then with clutch requires a lot more effort and its clunkier.
I thought about loosening the clutch, but with a NW chainring it doesn't seem to drop the chain.
Posted : 09/01/2017 3:10 pm
