I may be getting defy fitted with these brakes and I was just looking for a spare set of pads but I can not see any where that sells them and I wondered if they are pads fitted from an other calliper from the Shimano range.
Choice of 4 types of pad according to the tech docs. Part numbers are...
Y8LW98020 Resin Pad (G02A) & Spring w/Split Pin
Y8JZ98020 Metal Pad (G03S) & Spring w/Split Pin
Y8LW98040 Resin Pad (J02A) w/Fin & Spring w/Split Pin
Y8LW98030 Metal Pad (J04C) w/Fin & Spring w/Split Pin
Madison don't appear to have any of them in stock until the beginning of March.
Edit - same pads as XT 785
Thanks for the reply as I have never had Shimano brakes only Avid on all my MTBs. I always like to have a spare set of pads in case you have a problem.
Are they not these?
Finned: http://www.chainreactioncycles.com/shimano-xtr-xt-slx-alfine-f-type-disc-brake-pads/rp-prod61810
No fin, sintered: http://www.chainreactioncycles.com/shimano-xtr-xt-slx-alfine-g03s-disc-pads/rp-prod130818
No fin, sintered, Ti back: http://www.chainreactioncycles.com/shimano-xtr-xt-slx-alfine-g03ti-disc-pads/rp-prod61811
No fin, resin: http://www.chainreactioncycles.com/shimano-xtr-xt-slx-alfine-g01a-disc-brake-pads/rp-prod130820
