shimano saint/zee c...
[Closed] shimano saint/zee cranks
[#6685432]
i'm thinking of potentially getting one of the above for my bike.
but looking online i notice that some of the saint cranks say they fit 83mm bottom brackets whereas other sources say they fit either 68 or 73mm bottom brackets.
my bike has a 68mm bottom bracket shell so will the saint fit and if so do i need to refit the existing bottom bracket with more spacers to get it properly aligned or will i need a new bottom bracket?
if i choose to go for the zee cranks instead again will they fit on the existing bottom bracket or will i need to add more spacers or fit a new bottom bracket?
thanks in advance.
EDIT: i seem to say bottom bracket quite a lot in that message... 😯
Posted : 05/12/2014 2:41 pm
Saint and Zee are available in both 68/73 and 83mm. Just get one that says 68/73 and you'll be grand. Use 3 BB spacers to fit it (you probably already have three spacers on there). A new BB (with spacers) is generally included with the cranks by the way. HTH.
Posted : 05/12/2014 2:43 pm
You need to buy one which is for 68/73mm BB spacing.
It should come with a new BB anyway.
 gazc
i think m810 are 68/73mm bb and m815 are 83mm bb. similar for zee in that the last digit 0/5 indicates whether 68/73 or 83mm iirc
Posted : 05/12/2014 2:44 pm
that makes sense and having checked on CRC's website it seems to support what you say...but what do you make of this??
Posted : 05/12/2014 3:18 pm
 MSP
I think the left side are interchangeable for both models.
Posted : 05/12/2014 3:24 pm
It's m820 for 68/73 and m825 for 83mm on current gen kit
Posted : 05/12/2014 3:26 pm
that pair or going pretty cheap on ebay so thats why i was interested. i've just looked on the image for the inside of the driveside crank and it says m810 so what you said makes sense.
thanks!!
Posted : 05/12/2014 3:28 pm
http://singletrackworld.com/forum/topic/shimano-zee-chainset-170mm-36t
not me selling, by the way.
Posted : 05/12/2014 5:45 pm
