Hi, just got some new wheels. Wanted to increase rotor size from OEM. Presently 160/180.
Have acquired some Ice Tech 180 and 203.
Will the 180 brake adapter off the front fit the back? All fit post to post. The ones online, 180 rear look identical to the front I already have.
Also, will the ice techs run in my calliper ok?
Ta
Posted : 18/12/2015 6:30 am
Generally, post-post mounts are the same front and rear, so you should be able to swap one as you've suggested, and buy a new front.Ice-tech rotors should run fine in those calipers.
Posted : 18/12/2015 6:46 am
