Shimano chain - hav...
[Closed] Shimano chain - have i knackered it? (numpty content)
I split a shimano chain, and without thinking i split it at the first link i came to and the pin dropped out. I now realise i should of split it at a specific black pin on the chain.
Have i knackered it or could i use a new pin or SRAM powerlink to refit it?
Posted : 22/03/2010 4:03 pm
you did the right thing - just use another Shimano pin or SRAM link to rejoin it.
Posted : 22/03/2010 4:05 pm
Whats this thing about having to split it at specific link/pin then?
Posted : 22/03/2010 4:06 pm
Use a powerlink
Posted : 22/03/2010 4:14 pm
You have to join with a joining pin (or Power Link), you can split wherever you want, in fact it's better not to split at a joining pin, as they enlarge the holes slightly which can mean a second one doesn't fit as well.
Posted : 22/03/2010 4:15 pm
Best not to split it at the original pin, as has been said. If you're careful you can just re-join it anywhere with the normal pins - the old fashioned way if you like, without a special pin.
Posted : 22/03/2010 4:18 pm
Sram powerlink every time. You are supposed to use the black link to split but as someone pointed out they F the holes in the A. Powerlink is just so much handier for cleaning etc. I always carry a spare or two for trailside emergencies as well.
Posted : 22/03/2010 4:24 pm
All is not lost then, i will fit a powerlink. Cheers lads.
Posted : 22/03/2010 4:26 pm
Pop a power link in, I’ve had chains with as many as 3 power links in before, don’t bother with the shimano split pin, too much faff…
Posted : 22/03/2010 4:32 pm
POWER LINK, its the only way to go
Posted : 22/03/2010 5:07 pm
I tried to rejoin a chain with a powerlink the other day, 8 speed chain,make unknown, new silver powerlink, no joy at all, didnt look like the pins were long enough. Is there a magic knack cos im just about to buy a load of joining links instead.
Posted : 22/03/2010 5:21 pm
8 speed chains are thicker than 9 speed so need a 8 speed quick link.
8 speed links will work with 7 speed chains tho.
Posted : 22/03/2010 5:48 pm
thats right, and the gold are 9 speed arent they?
Funny thing is the one on my bike I can work fine
Posted : 22/03/2010 7:10 pm
