I’m gutted to be asking a technical question but I’m not 100% sure...
I have, on order, a Deore 10 speed M610 shadow rear derailleur to use with a Shimano 9 speed shifter and cassette.
Will this actually work or is the leverage ratio different between 9 and 10 speed?
8 and 9 yes, 9 and 10 no.
Damn. Thanks dovebiker
Nope, Won't work.
Useful shifting info has been updated with some more 10/11 speed dynasys numbers recently...
Jtek Shiftmate 6, if you want to blow another £30...be interested to hear how well it works if you do.
http://www.jtekengineering.com/shiftmate/shiftmate-compatibility-charts-choices/
A sram 9 speed shifter will work if you fit the cable funny.
Going back some years there used to be a fix where you could add a couple of washers under the cable. Then someone made a 3mm brass block to replace the washers. What it does is lengthen the lever so for every pull of the cable the mech moves a little less.
