Setting up road cle...
Setting up road cleats
Anyone know of any good guides or systems to follow when setting up road cleats (SPD-SL's if it makes any difference).
I need to give my position a tweak (due to an injury) and I've not changed set-up since I have a bike fit about 10 years ago.
Posted : 06/11/2025 5:19 pm
I think the modern thinking is cleats as far back as possible. There may be arguments over efficiently but it's the least likely position to cause injuries
Posted : 06/11/2025 6:27 pm
Need to change things due to an injury sounds like a bike fit job to me ideally by someone who can properly assess the injury.
Posted : 06/11/2025 7:21 pm
FWIW mine (from a bike fit) are roughly pedal spindle in line with that big bony lump at the base of the big toe.
Posted : 06/11/2025 7:22 pm
Posted by: garage-dweller
Yeah, agreed, but realistically that’s not going to happen. So an online guide would be useful.
Posted : 06/11/2025 8:47 pm
Posted by: Onzadog
This.
Lower and advance the saddle slightly to compensate.
Posted : 06/11/2025 8:53 pm
Put them back as far as possible and level. The float in normal SPD-SL cleats should take up a reasonable twist but if you need more then move a little bit at a time until they're comfortable. Using a turbo trainer really helps too.
Posted : 06/11/2025 9:31 pm
