Setting up a top gu...
[Closed] Setting up a top guide...
7 Users
Obviously I lucked on getting it right last time but after replacing my crankset (old square taper deore thing for a truativ noir and hope chainring) I can't get it even close to running right.
Any tips on how to set a superstar top guide so its quiet and doesn't rub???
Posted : 25/03/2013 9:32 pm
Throw it away and buy an e13
Posted : 25/03/2013 9:39 pm
Throw it away and go single speed.
Posted : 25/03/2013 9:42 pm
A) not spending 75quid on an e13 one
B) done SS before and not doing it again!! 😳
Posted : 25/03/2013 9:59 pm
Side rub or top and bottom?
If it helps ended up shimming my m part one with brake shims between the cage and the arm.
Mpart guide + shimano crank - fail.
If i had iscg mounts I would spend the extra!
Posted : 25/03/2013 10:04 pm
Side mainly. But got too cold to carry on faffing 😳
Posted : 25/03/2013 10:43 pm
Most guides I've fitted ended up having to be adjusted with shims and or bent grinded beaten
Into a shape place where they don't rub
But worth the time to make them silent
Posted : 25/03/2013 10:46 pm
This:
My superstar on is also shimmed, bit of plastic and some cut up inner tube.
Posted : 26/03/2013 8:38 am
Got a pic of the setup?
Posted : 26/03/2013 8:48 am
Bike is in the car, will got take a pic at lunch time.
Posted : 26/03/2013 9:03 am
Quick pic this morning after my fingers defrosted...
only seems to rub at very top and very bottom gears.
Posted : 26/03/2013 9:05 am
That looks like the same moulding as the m part cage. Iirc changing the angle helped as there are wide and narrow bits in the opening.
Failing that Might need to file it or ignore the rub.
Posted : 26/03/2013 9:23 am
