Anyone know where I could find one of the above, or does any one have one in their parts bin, discontinued and my googling doesn’t throw up anything.
TF tuned has stock of it in 150mm and soft in 140, anyone know if the springs are the same length and the lower shaft is the length difference? If so can buy both and swap bits over
I'm wondering this too, googled it and this post was the only clue...
Guess I'll ask TF Tuned.
If its U-turn then can you not just wind it in 10mm to make the 150 into 140mm?
I have a UTurn spring fitted into an old Fox Talas fork and I remember the top section sort of threaded into the lower section (shaft) to change height.
... forgot to say - I have a spare 140mm uturn spring but its Medium....
If you do find that a regular non u-turn spring in 150mm will work, then I have a firm one I would sell. Very little use. Mail me.
i ended up using a firm 150mm u turn, the spring are not able to be swapped like the dual position, my revs are 150mm travel, takes a 140mm in dual position but a 150mm in u turn as oddly the springs are the same lengh
