Seized cassette loc...
[Closed] Seized cassette lock ring......what to do?
 SiB
[#1849589]
Chain whip and lock ring removal tool in place but will not budge after a couple of hours of soaking in wd40 and plenty of force applied, its a 'new' 12 year old bike so not sure if cassette ever removed, can they be fused together like the seat post and tube are on same bike (which isnt a problem as ideal height)
Any ideas?
Posted : 31/07/2010 5:21 pm
Never seen one seize. Try more leverage. Or a new freehub.
Posted : 31/07/2010 5:24 pm
What he said ^
Posted : 31/07/2010 5:26 pm
Can be very tight. Give it some welly. Hold the removal tool in with the QR and get a 2 or 3 ft lever on the spanner and chainwhip
Posted : 31/07/2010 5:27 pm
Copius amounts of PlusGas overnight and try again
WD40 isn't much use as a penetrating agent and PlusGas is far more effective
Posted : 31/07/2010 5:33 pm
 SiB
Will give it more wellie after a good soaking tonight, maybe its sign to warn me against single speed??
Posted : 31/07/2010 5:37 pm
a mighty chainwhip with much leverage like so:
Worked (eventually) on my stuck rohloff lockring...
Oh and make sure you're working in the right direction - I've made that mistake too.
Posted : 31/07/2010 5:42 pm
 jonb
LBS? They will have the experience and tools. Mine charged a pittance, and it was worth it to save the wheel and time. Might even do it free if you buy the casette. Failing that find some pipes as above.
Posted : 31/07/2010 5:55 pm
tool in lockring secured by qr, place tool in a bench vice, then use a chainwhip and a long leverage bar.
Posted : 31/07/2010 6:03 pm
Apply a little heat with a blowtorch or similar, works everytime. Be sure to thouroughly re-grease the area afterwards though!
Posted : 31/07/2010 6:07 pm
Ensure you have the right remover, some fit into the body and undo the whole block, as opposed to a lockruing which is a relatively modern idea.
Posted : 31/07/2010 6:10 pm
Not many people still use a screw on block these days though.Just to clarify what hub is this on?
Posted : 31/07/2010 6:31 pm
