scott genius shock ...
[Closed] scott genius shock creaking promlems - help !!!!!!!
4 Users
my shock creaks when locked out - anyone had any similar problems? had it serviced and it still makes the same anoying noise, doesn't seem to move and the lockout feels ok it's an older tc 90 - 125mm from 05 i only use the lockout for the road but it's driving me crazy none the less !!!!
any ideas welcome
Posted : 15/03/2010 6:53 pm
 Pete
Maybe silly question, you sure its the shock and not some of the mountings
Posted : 15/03/2010 7:11 pm
Or if it only does it when its locked out, a broken post or frame??
Suspension will take most of the stresses away when its working, switch to lockout and there is a whole heap more stress going on
J
Posted : 15/03/2010 7:57 pm
yes definately the shock, checked the frame over very carefully and the post - i've tried pumping it right up to the maximum pressure recomended and it's much better and almost dissapears but obviously the suspension is way too hard, as soon as i let it back down to the right pressure for my weight the creaking's back ??? i'm guessing there's something amis internally ?
Posted : 15/03/2010 8:14 pm
dandc - ygm
Posted : 15/03/2010 8:40 pm
