Hi all
I have a new 2014 scott genius 29er on the way and just wondered if anyone has fitted a reverb stealth to theres.
I know its a 31.6 but what I am unsure of is the length, is a 380mm or a 420mm best, and what side remote to order.
cheers for your help.
Which ever length gives you the full height extension you need.
I run a 5" DOSS as a 4" post won't give me enough pedalling height, other guides are fine with just 4.
Lever wise, whatever your pref. And if you want it under or over the bars.
Going 1x 10? I'd do right hand mounted on the left side under the bar where the shifter was. Sticking 2x the on the right side away from the twinloc... Under or over is your choice..
(Under means using a lever for the other hand I.e right side under would be a left lever)
Cheers, I think it's best I wait for the bike to turn up before I order one. Getting excited and want to have it all ready to go. ?
