Santacruz Nomad Mk1...
[Closed] Santacruz Nomad Mk1 1.5 headtube - zero stack reducer headset ok?
will I have clearance issues on the down tube from my forks (2009 fox van 36) if i use a hope 'step down' headset (the flush one, not the one with a 10mm lower cup)?
anyone successfully run nomads with zero stack headsets?
Posted : 16/02/2010 12:00 pm
bump ๐Ÿ˜‰
Posted : 16/02/2010 4:30 pm
 Ewan
The MK 1 Nomad has a 1 1/8 headtube... at least mine does!
Posted : 16/02/2010 11:54 pm
the last model of the mk1 (2008) has a 1.5 headtube. do you run zero stack?
Posted : 19/02/2010 12:34 pm
i have a 1.5" nomad with vans and I reckon you will have problems. I can't remember which headset I tried 1st (but it wasn't a zero stack), but the fork crown hit the downtube.
I ended up ordering a few from CRC and eventually went with the Cane Creek one.
Posted : 19/02/2010 1:06 pm
