Salsa Fargo, would ...
[Closed] Salsa Fargo, would it be very, very wrong ....
 PJay
to run with a flat bar or low risers?
The Salsa Fargo looks just the bike for me, but states that it's designed as a drop bar mountain bike; would their be any problems running a flat bar or perhaps low risers?
I don't really want drop bars and would like to use my existing hydraulic brakes.
Posted : 03/07/2014 7:57 am
If you want to run flat/riser bars, why a Fargo and not an El Mariachi?
Posted : 03/07/2014 8:02 am
 PJay
The Fargo is a little lighter and seemed a slightly better fit for the sort of mixed on/off road that I do; it also has rear rack mounts which I don't think that the El Mariachi does.
The El Mariachi is a possibility though.
Posted : 03/07/2014 8:06 am
Looks fine to me
Posted : 03/07/2014 8:12 am
Looks very short, does it have a short top tube as they are expecting you to be on the hoods?
Posted : 03/07/2014 8:39 am
Looks fine to me
I think you may have posted the wrong picture to go with that statement ๐Ÿ˜ฏ
Posted : 03/07/2014 8:48 am
I went through the same thought process but ended up buying a Surly Ogre frame. I like mine it works really well all the mudguard and rack mounts work well but it is a little heavy.
Posted : 03/07/2014 8:51 am
I have an El Mariachi and love it, and the flexibility it offers.
I'm 5'10" and riding a medium frame. To get the position I want for general riding I have fitted a 17 degree stem turned down, no spacers, and flat bars. For loaded rides I turn the stem up and fit low rise bars instead.
I suggest it would be worth comparing the geometry, stack/reach, between the two frames, and get a test ride if you can.
Posted : 03/07/2014 9:02 am
