I'm starting to plan a new build but to keep costs from getting too silly aim to reuse various bits including the wheels/hubs.
Can't seem to find anything online but Is there a free hub body available to do this with pro II (non evo)?
Any one shed any light on this?
Yes there is.. Not sure on the part code but I know there is an option on the dealer system for wheel builds.
You will also need to change the axle end caps for an XD specific version.. although if you have a file an 20mins you can make a regular 10/12mm fit.
You can also convert pro 2 to evo spec quite easily- the hub shell is the same and you're already replacing the most expensive of the components that needs replaced. No major benefit for non-maxle users though.
Ok thanks
Hope Pro 2 (non evo) to XD freehub.
Choose your end caps and choose XD freehub.
http://www.justridingalong.com/pro-ii-evo-upgrade-kit.html
OK
Freehub is part HUB526 inc QR end caps
HUB526:10 with 10mm
HUB526:12 with 12mm
HUB526:X12 with X12
