Converting a Straig...
[Closed] Converting a Straight Pull Hope Pro2 Evo back to 135mm?
[#6310058]
I have a Hope Pro 2 EVO Straight pull rear hub currently set up as an x12 142mm. How do I convert this back to a 135mm QR?
Is it just a case of pull off the end caps? Is there any difference between a SP and a 'normal' pro 2 evo when it comes to altering the axles
Posted : 01/07/2014 6:05 pm
Just pull off the end caps and put the 135mm ones in. job jobbed. both hub shells are the same diameter and width.
Posted : 01/07/2014 6:12 pm
