Running Minion DHF ...
[Closed] Running Minion DHF as a rear tyre?
7 Users
Heard this is quite good
Do you run it the normal way (as indicated by the tyre) or back to front?
Posted : 17/04/2010 10:46 am
 awh
Do you want more grip or less rolling resistance?
Posted : 17/04/2010 11:53 am
The latter
Posted : 17/04/2010 11:58 am
 GW
ignore awh's pointless question. run it the same way as the front!
if you want less rolling resistance choose a completely different tyre.
Posted : 17/04/2010 12:15 pm
 awh
My question was somewhat in jest. The biggest benefit will be from swapping to Minions, not which direction you run them. At the moment I'm using and liking a Minion DHR! Both are great tyres 😀
Posted : 17/04/2010 12:47 pm
Ta
Posted : 17/04/2010 12:52 pm
 GW
DHRs are alright, until it gets wet (similar characterisdtics to a Michy Comp 24) and work pretty well as a rear with a DHF up front but the two are not front and rear specific tyres and were designed for a different range of conditions and IME a DHF copes better than a DHR in pretty much all conditions.
Posted : 17/04/2010 1:14 pm
Sort of hijack, are the DHF good as a front tyre for all round use? I do a bit of everything apart from real hardcore DH and my Nevegal is pretty rubbish at keeping its grip when turning.
Posted : 17/04/2010 1:48 pm
I like mine - run the harder compound on the back and the really sticky compund on the front. Great even on wet roots. You can hear them trying to pull the tarmac up on road though!
Posted : 17/04/2010 2:11 pm
_tom_ - I ditched my huge 2.5 negeval for a minion DHF and found it must better on front. It's on my coiler so whilst it's not an xc bike it doesn't seem to cause too much drag or weigh it down too much.
Posted : 17/04/2010 3:42 pm
Ace tyre, normal way round, front and back here. Ardent 2.25 on the rear now though, faster and still grippy in drier conditions. As big as a 2.35 Minion DHF as well.
Posted : 17/04/2010 4:37 pm
