Rs stanchions repla...
[Closed] Rs stanchions replacement
9 Users
Wrecked my new pike rt3 stanchions on Saturday in a pretty spectacular crash, only used them for about 5 rides so is worth buying new stanchions and getting them fitted by a lbs or a buy new full set?
If so any deals around?
Posted : 04/08/2014 7:14 am
If you have the part number take a look at Petra Cycles website for Rockshox spares. I reckon the stanchion assembly is going to be around £200 though...
Posted : 04/08/2014 9:57 am
Solo Air or Dual Position? 26 or 29?
All are in stock with Fishers, all are (wait for it) £329, if you've got the variant I can give you the part number.
May be cheaper elsewhere, but that's retail.
Posted : 04/08/2014 10:00 am
Just had a quick look and the crown assembly is retailing for around $350 (can't locate any in the UK so far) so you're definitely better off going for a new fork if the stanchions really are trashed.
Posted : 04/08/2014 10:14 am
They're the single air.
http://pbckt.com/pf.JhZW29
Posted : 04/08/2014 3:54 pm
That's expensive but still cheaper than new forks. I suppose the question is whether the other bits have any value- maybe someone'd buy the dampers for a set of Lyriks or Boxxers?
Posted : 04/08/2014 3:57 pm
I've just spoke to loco, going to drop them in to see if they're worth repairing
Posted : 04/08/2014 4:22 pm
Is it not cheaper buying those RC Pikes from the French mob for 310 quid,change out the RCT3 damper
Posted : 04/08/2014 5:42 pm
Yeah, i'd say RC from the frogs and change the inners over would be your best bet, then get the lowers on ebay to recover £100 or so.
Would the RC and air spring drop into a Lyrik fork? If so you could probably get £150 or so for that maybe?
Posted : 04/08/2014 5:51 pm
I'd not thought of that, could be the plan. Cheers
Posted : 04/08/2014 8:20 pm
(profiteering from other people's misfortunes) if you were to happen to get a 26 inch, 160mm dpa fork, I'd be interested in taking the spring off your hands 😉
Posted : 04/08/2014 8:25 pm
Can I use the bits off a 26"?
I've got 150mm 650b 15mm solo air.
Which store is the French one?
Posted : 04/08/2014 8:29 pm
Great, thanks for that.
Posted : 05/08/2014 6:55 pm
therag, if you have charger damper from your old pike for sale, send me email. Thanks
Posted : 23/09/2014 12:34 am
Have you spoken to a LBS? May be worth seeing if there is a crash replacement price? Unless you bought it online in which case they probably won't be up for doing any favours.
Posted : 23/09/2014 12:36 am
You need to buy a 650B Pike fork for the correct CSU. 26" and 650b have different part numbers.
Posted : 23/09/2014 9:49 am
