Not sure if this is a RS trait but cannot find anything on the tinternet to help .
IM getting a top out end of travel clunking, and the first 1/4inch is neither compresion or rebound just nothingness.
I can hold the Bridge of the fork down and pull the crown up 1/4 inch almost like its got play in it.
Rebound turned all the way to slow is better (but why have an adjuster if you can only have it on slow)
any tips or advice would be cool
ta
Mine doesn't do this. I think yours is broken. Warranty?
Thats the negative spring,Its meant to have that.
Only a couple of rides old Buzz ๐ and think they clunked from the start.
Cannot find any info on a negative air spring. ๐
๐ clunking.
I thought "negative air spring" was to do with dual air. Sektor are solo air. Where is P. Poddy when you need him? ๐
Something sounds like it may have come loose, send them back for warranty repair.
Ok loco. I will look into that. They are on a new Pitch pro so would I go through any Specialized dealer or with SRAM.?
Deal with the shop where you bought it first.
Specialized dealer should be able to help if original shop not local, take biscuits or cake though ๐
If they were dual air I'd say you didn't have any air in the bottom chamber as this happened to my Pikes the other week but being solos I have no idea unless the equalisation vent is blocked (I'm assuming there is a way to go fom one chamber to the other)
Trying to narrow things down a bit I tryed a different front wheel with a expencive hub (not a spesh Hilo jobie) and its 50% better. ๐
so off to a spesh dealer to see if they can do anything in the morning!
