RS Dual Air Problem...
[Closed] RS Dual Air Problem.
[#1545103]
I serviced my SID forks over the weekend, lowers were off so both chambers were empty, after inflating the +ve to 120psi, I attached the pump to the -ve and it registered 10psi already in the chamber, I presume I have a leak somewhere, anyone?
Posted : 26/04/2010 10:40 am
 IA
Or the pistons just moved about as you re-inflated. It's probably fine.
Could be a leak though, empty the negative air, let it sit a while and re-check.
Posted : 26/04/2010 10:44 am
Ah good call, never thought of that, however I've inflated them a couple of times and the same thing happens.
Posted : 26/04/2010 10:46 am
I wouldn't presume you've got a leak straight away.
When you depressurise the chambers they will change volume. As you pressurised the positive chamber again it could just have made the negative chamber smaller, increasing the pressure in that chamber.
If you had a proper leak then it wouldn't stop at 10 psi, it would keep leaking until the 120psi in the positive chamber had spread itself equally between the two chambers, giving you something like 80psi (complete guess there) in both chambers
Posted : 26/04/2010 10:48 am
That makes perfect sense, thanks.
Posted : 26/04/2010 10:52 am
That makes perfect sense to me. As you inflate one chamber, you're effectively putting the squeeze on the other chamber. 🙂
Posted : 26/04/2010 10:53 am
