RS Damper Service
[Closed] RS Damper Service
4 Users
Is it possible to change the oil in the damping unit of the rockshox pikes with the lowers installed?
Posted : 17/01/2010 7:19 pm
or do i have to remove the lowers to do this???
Posted : 17/01/2010 8:55 pm
As long as it hasn't leaked it's oil into the lower leg you can do it all from the top.
Posted : 17/01/2010 9:26 pm
Tried doing it as had already put the lowers back on, the fork is now solid, why is this?
Posted : 18/01/2010 12:41 pm
Too much oil.
Posted : 18/01/2010 12:44 pm
thats what i thought, I used 140ml?
Posted : 18/01/2010 12:50 pm
Should be 120ml according to Sram's oil level chart.
Posted : 18/01/2010 7:03 pm
Why not take the lowers off? It only takes a 5mm allen key and you can then clean the inside of the lowers and dust seals / stick plenty of Red Rum on them.
Posted : 18/01/2010 7:23 pm
