RP23 Shock has an a...
[Closed] RP23 Shock has an annoying squeek, but only when propedal is on.
As soon as I switch the propedal off it disappears.
I changed all the air seals last week so it's nothing to do with them.
It's started to drive me up the wall a bit.
Posted : 04/06/2015 10:54 pm
Did you lube your rings up well before install and then put 2cc's in the aircan?
Posted : 05/06/2015 12:01 am
I had an issue like that before, turned out to be an issue with the nitrogen chamber so needed a full service
Posted : 05/06/2015 6:33 am
I did put the 2cc's in the air can and lubed it all up.
Maybe it is something that needs looking at in a full service? It's driving me slightly crazy now.
Posted : 05/06/2015 7:11 am
there's nothing like an annoying squeak to ruin yer day
Posted : 05/06/2015 8:01 am
Exactly the same problem here. I assumed nitrogen but it was still the same after sending off for a service in my case...
Posted : 05/06/2015 8:54 am
That's not what I wanted to hear.
Posted : 05/06/2015 6:08 pm
