RockShox Solo Air O...
[Closed] RockShox Solo Air OB - Can I remove a spacer without an oil change?
If I undo the bottom legs of my forks, find a pair of circlip pliers, remove the left spring leg as per the rock shox manual and add/remove spacers to my hearts delight, do I need to completely drain the left leg and refill the damping leg?
Or can I remove the lowers, set them aside mouth up and work on the spring leg, lightly relube the spring leg parts and put it all back together?
TL:DR can i change a solo air spacer with only some float fluid / suspension grease to hand
Posted : 16/04/2012 7:05 pm
