Rockshox Revelation...
[Closed] Rockshox Revelation help required
 Kip
Ok, so, I've just bought a set of "Rockshox Revelation 426 130mm dual air forks" (as described) via a well known auction site. On receipt I checked them out as they looked a bit short and have discovered that the stanchion length is only 125mm (regardless of pos and neg air pressures). The instruction book is dated 2005 and I think they are 06-08 forks, the lowers are kind of dark maroon in colour. It seems they were available in 100mm, 115mm and 130mm. They are NOT U-turn. Am I being some kind of numpty or do I have a reason to get a bit shirty with the seller?
Oh yes, at NO time was reduced travel due to spacers mentioned so he has no out on that. We think we have found 1 spacer in the pack with the fork but aren't sure.
Cheers for any help. I'd like to be fully informed before I get annoyed.
Posted : 13/05/2011 8:33 pm
they are 130mm and reqiuire a 5mm spacer to be removed off the air side piston
Posted : 13/05/2011 8:42 pm
 Kip
Before I take them apart it appears that the 06-08 were available in 115mm. Is there any way to check that it is definately due to a spacer and not the wrong length fork. Or were they standard forks (130mm) but with spacers fitted as standard to reduce the travel to whatever they were sold as?
Posted : 13/05/2011 8:46 pm
all 130 with spacers as rebas filled the other gap iirc
Posted : 13/05/2011 8:48 pm
 Kip
Cheers. Worth getting narky about with the seller? I'll be honest I was after u-turns but in a hurry misread the description and got these. It does mean they are a better swap for my old forks as well! But that's not the point!!!
Posted : 13/05/2011 8:54 pm
for what reason, you not reading the ad properly?
Posted : 13/05/2011 8:56 pm
 Kip
No, the bit that said they were 130mm forks when they are clearly not, without some fettling on my behalf. I know I read the ad wrong, and I'm not complaining about that, that was my own fault so have to suck it up! I wanted the adjustability of U-turns so I could see how the longer travel handled compared to the shorter but I'm happy enough with these. As I say, it's more the fact that they are not 130mm travel as described.
Posted : 13/05/2011 9:15 pm
