Looking at getting some nice big discs for some lyrik forks, hopefully running a 203 on the front, but question is, will I just need a normal 203mm post mount adapter?
I know some of the newer forks already have a certain rotor size built in (I think the Fox 36's are built for 180mm from factory for example).
Thoughts welcomed!
Lyrik is , bizarrely, a 160mm straight mount 😯 . I've an adaptor for my 180mm
Yeah that is a bit strange... well I've got the right adapters for that so it actually works out better. Cheers!
I think the Lyrik lowers are basically unchanged since the dawn of time - the ark had domains fitted, Noah was too tight for Lyriks- so probably different attitudes prevailed
No wonder the Ark got stuck on that hill then, no fast compression damping!
I'm currently in an inner-debate whether to go for lyriks for an NS surge, or Revelations... decisions decisions
