are they air or oil???
Posted : 29/04/2012 9:53 pm
Coil spring
are they easy to service as mine are a little spungie???
Posted : 29/04/2012 9:56 pm
Same as any other RS fork to service if they have turn key damping they are the same as a tora. When i had some 100mm one's they took 93ml of oil in the damper.
Posted : 29/04/2012 10:05 pm
They are oil and coil. Alternative would be air and oil which they certainly are not.
Posted : 29/04/2012 10:33 pm
Easy enough to service, I've just done one. Theres a PDF tutorial here:
£12 for a seal kit, (same as the older Judy fork)I'd also recommend the O rings, as one of mine was split, and the crush washers for the bottom. A good clean and service made a big difference on my lad's bike. Err on the side of less when topping up the rebound oil or your travel will be reduced. I just dropped in 90ml instead of 93. 😉
Posted : 29/04/2012 11:07 pm
