Have bought frame and shock, starting custom build.
Top shock mount is fine , bottom mount bolt is at 90 degrees, horizontal?
Is there an easy way to twist the lower half of shock to suit mounting bolts?
Thanks
Blair
Posted : 22/12/2014 10:10 pm
Cant you just turn the bottom of the shock? I've done that in the past.
Posted : 22/12/2014 10:26 pm
The shock can rotate freely (though can be fairly stiff, especially if it's charged up). Putting the shaft end in the frame then turning the body is probably the neatest way
Posted : 22/12/2014 10:43 pm
Thanks chaps.
Posted : 22/12/2014 11:08 pm
