Road hub Q : Can yo...
[Closed] Road hub Q : Can you fit an 8spd cassette on an 10 speed hub?
I want buy a new pair of wheels for my son's road bike. He uses 8 speed Tiagra shifters, will I be able to use an 8speed cassette on a 10 speed hub. The wheels I want to buy are Campy Khamsins. Like these http://www.tredz.co.uk/.Campagnolo-Khamsin-Pair-Road-Wheels_27175.htm
If one can't run it like that, could I use a 10 speed cassette and will it work with the 8 speed shifters, except for not shifting into the last 2 cogs?
Posted : 31/01/2011 2:47 pm
The answer to the second part of the question is no, a 10 speed cassette will not work with the 8 speed shifters.
Posted : 31/01/2011 3:07 pm
If the freehub body on the wheels is a 10 speed specific then you won't be able to fit an 8 speed cassette on it. My knowledge of Campag wheels is not great but the description does seem to infer they are 10 speed only so no good to you.
Posted : 31/01/2011 3:09 pm
You won't be able to use any Shimano cassette on those wheels either as they are a Campag free hub and if you used a Campag cassette there are dramas involved in getting the indexing to work with shimano shifters.
Posted : 31/01/2011 3:13 pm
Rockhopper, you can choose between Shimano or Campy freehub.
Thanks MrP, you're probably right, though it is not what I was hoping to hear 🙁
Posted : 31/01/2011 3:16 pm
I thought Shimano freehubs were cross compatible 8-9-10s?
In any event, Tiagra is either 9 or 10!
Posted : 31/01/2011 3:29 pm
Cynical-al, you are right, it is 9 speed, and I found a link to Campagnolo Tech section and it would appear that the freehub will work fine with a 8,9 or 10 speed cassette 🙂
5.3 - 8S, 9S, 10S SPROCKETS FROM SHIMANO INC. and SPROCKETS
FROM SRAM CORPORATION (on the Campagnolo® freewheel body
for Shimano Inc. 8/9/10s sprockets and Sram OG 1070 - OG 1090
sprockets)
Posted : 31/01/2011 3:55 pm
[i]I thought Shimano freehubs were cross compatible 8-9-10s?
In any event, Tiagra is either 9 or 10! [/i]
The majority are but there are a few out there that are shorter and hence 10 speed specific. Dura Ace 7800 for example. Like I said, my knowledge of Campag wheels is not great and the advert did intimate at being a 10 speed only body. It is good news that it is not.
Posted : 31/01/2011 4:53 pm
 dobo
fwiw an 8 speed shimano cassette will work with 10 speed campy ergo shifters and shimano 9 speed rear mech!
Posted : 31/01/2011 8:08 pm
That's odd... I use 9s ergo, 8s shimano cassette and shimano rr mech 8or 9s...is road 10 different?)
then again a mate used a different combo again which worked.
Posted : 31/01/2011 8:19 pm
 dobo
all sorts of good info on here
http://www.ctc.org.uk/DesktopDefault.aspx?TabID=3946
Posted : 31/01/2011 8:42 pm
