Rip in side wall of...
[Closed] Rip in side wall of a road tyre. What's the best bodge.?
Got to the bottom of my road today and found a rip in the side wall of my conti GP4000s and a lot of air leaking out. I have patched it up with a patch and some emery cloth (strong none flexi material to stop the bulge) but is there a more permanent fix or should I just bit the bullet and get a new one.?
Posted : 21/02/2012 6:56 pm
Get a new one, high pressure and damaged tyre = painful future
Posted : 21/02/2012 6:58 pm
sew it with dental floss, patch in the inside with a large puncture repair patch
That's what I was thinking. Always bodged MTB ones but I'm a bit worried about doing the same with a road tyre.
Posted : 21/02/2012 7:04 pm
 irc
No idea how repairable it was but riding a tyre I'd sewn up at 40mph downhill doesn't appeal to me. Either it works and you've saved a few quid or it fails very painfully. Your choice?
Posted : 21/02/2012 7:57 pm
New tyre! 100 psi can explode , bad to fall on roads too, ESP with cars around.
Posted : 21/02/2012 8:15 pm
Had a GP 4 seasons with a rip. Used a tyre boot to repair. Only took a few rides for the boot to fail. Did it again (had no money to buy a new one and payday was a couple of weeks away), this time it went pop as I was riding along road
Posted : 21/02/2012 8:45 pm
Jesus, I've just replaced a newish tyre with a 3mm glass cut and just one thread in the carcass cut through. I simply do not want to be in any doubt about it.
Posted : 21/02/2012 9:00 pm
I'd definately be looking to replace at first opportunity for all reasons above - but the best bodge has to be a folded tenner between tube and tyre
Posted : 21/02/2012 9:04 pm
Depends on the size of the cut. Superglue makes cuts vanish, serious, you will find it almost impossible to find the cut once its been superglued properly. Obviously not a ten inch rip, but globati , 3mm glass cut can be fixed.
Posted : 21/02/2012 9:21 pm
I've know of someone who's sewn up a tear in the sidewall of a GP4000s. It's been fine since but I'm not sure I'd like to try it. I would say that if you're going to do it, put it on the back.
Posted : 21/02/2012 9:47 pm
Its worth noting that tubular tyres are sewn up along their entire length and they hold to 200psi! However as i said, a rip is a bit different and id question the longevity of a repair in a place where it could be damaged again.
Posted : 21/02/2012 9:51 pm
Park tyre boots seem to work well; currently running one inside a badly cut Gatorskin (roadside fix) to see how long it lasts.
Paper money is a reasonable alternative (retains its strength when wet).
Posted : 21/02/2012 9:55 pm
Stato, the difference is that they are designed to be tubular and the stitching is against the rim, with glue holding it on. No on an unsupported very flexible sidewall.
Posted : 21/02/2012 10:25 pm
Anywhere near the bead and bin it
Posted : 21/02/2012 10:29 pm
My last one on a nearly new tyre, luckily I wasn't going downhill.
Posted : 21/02/2012 10:31 pm
A bit of a pop bottle to make a tyre boot works, it's a ghetto tyre boot.
Posted : 21/02/2012 10:33 pm
I sewed up a tyre then rode if a few times to show I had faith in my work, now it's just used on my turbo where it's doing well.
Went through this myself. Started a thread, "bin it" said the majority! "Fix it", said the few..
Fix attempted, another fix attempted..etc.
Binned it.
Posted : 21/02/2012 10:48 pm
I used a puncture repair patch on the inside of the tyre and superglue on the outside to repair a pro 3 race. I'm fairly okay with it on the rear but wouldn't use it on the front. It's in the spares box as an emergency tyre that I would use for a couple of days maybe if I had to wait for a new tyre.
Posted : 21/02/2012 11:18 pm
you're mad to consider anything but a get-you-home fix imo, would be very difficult to keep the tyre shape even without the safety risk or inconvenience of it blowing 30 miles out.
Posted : 22/02/2012 12:08 am
OP tubeless patches don't stretch and may work.
May be no logic in it but I'm wary of fixing slashes in HP tyres.
Posted : 22/02/2012 12:16 am
