I have a 22.4mm internal rim to tape. From what I've read I need tape that's about 2-3mm wider so was going to get Stans 25mm ( next size down is 21 ) but I have a big roll of 21mm that I used for a different set of wheels, will 21 work with a 22.4mm rim if Im really careful to keep it central? Thanks
I've never had any luck with 'proper' tubeless rim tape, even stuff that is the recommended size. Therefore, in my experience, I'd say probably not.
My solution now is to use clear gorilla tape, run it all the way over the bead lip, and then trim it off.
I've used 29mm rim tape in 30mm rims without issue.
The bit that you're taping on the rim isn't usually flat. Although your rim measures 22.4mm wall to wall, it dips in the middle where the spokes sit.
That's going to reduce the effective width of the tape. Once it's applied, measure across the tape and it'll probably only be covering say, 19-20mm of the rim leaving a mm or 2 gap either side.
The issue here is that when you come to fit the tyre, there's a good chance your going to squish the tape which could cause it to
a) not seal
and
b) the tape could come unstuck once the tyre is on.
If the tape comes unstuck and lifts, it won't seal. Also, even if you don't squish the tape fitting the tyre, you're relying purely on the sticky part of the tape to hold it to the rim (which to be fair, it should do. That's kind of it's job).
Technically, yeah it'll probably be fine but if you use wider tape that extends up the inner wall of the rim, the bead of the tyre will help to keep the tape in place. In that situation, you got the tape and the tyre sealed against each other. If there's a gap between the bead and the tape, you've got the edge of the tape as a possible source of a leak.
Saying that, I used 29mm(?) tape on an i30 rim and it was fine even though it was nowhere near the wall of the rim.
Not endorsing going against the manufacturer's recommendations obviously, but I didn't die.
Yeah, I don't find using the wrong size a problem.
No issues at all, I've got a roll of 25mm Tesa 4289, I have used it on 19mm, 23mm, 24mm and 30mm rims with zero issues. Rough up the rim paint and then clean. Make sure to stretch the tape when you apply it. I would highly recommend putting a tube in after applying the tape, even for 20 mins.
Thanks all
