Rim tape for non-tu...
[Closed] Rim tape for non-tubeless
Sorry for what must be a common question. I've searched but not come to a conclusion.
I'm running WTB i29 rims with tubes. The rim tape could do with renewing. When I search for rim tape pretty much all the hits are for tublesss tape.
Can I use tubless tape? Any recommendations and what width would you go for?ย ย  Thanks
Posted : 30/10/2020 1:54 pm
Just use any tape (parcel tape, duct, electrical) it really doesn't matter.
Posted : 30/10/2020 1:59 pm
...but I just went for the appropriate tubeless tape for my rims, was precisely the right width, doesn't move anywhere and seems to help awkward tyres mount easier.
Posted : 30/10/2020 2:29 pm
Always used electrical tape for tubes personally, both on my bikes and when doing customers' replacement tape
Posted : 30/10/2020 2:33 pm
OK, thanks for the replies.... the bottom line seems to be that it doesn't really matter what I use.
If I went the tubeless tape route would I be best to go for the appropriate width for the rims, which for the i29 seems to be 29 + 5 = 34mm? Or as it would be for tubed doesn't it matter as long as I cover the spokes?
Posted : 30/10/2020 3:56 pm
The whole tubeless tape thing is a con, all you need to do is cover the spoke holes and any sticky tape will work.
Posted : 30/10/2020 7:24 pm
If you want non-tubeless rim tape, then it is available...
https://www.sjscycles.co.uk/rim-tape-accessories/
Posted : 31/10/2020 9:31 am
If I'm on tubes - that is rather infrequent these days, at lest for me - I'm avoiding sticky tape, and just going for recommended or closest available to recommended width, removable, plastic/vinyl tape. No sticky residue, no faffing around. Just pop it in, done.
Cheers!
I.
Posted : 31/10/2020 12:49 pm
Lots of useful feedback. Thanks
Posted : 31/10/2020 3:29 pm
For me it depends on the rim and tyre.
If its not tight I would just run a decent snap in rim tape (not the cheap stiff plastic ones), takes seconds to fit and can be removed to replace a spoke etc.
If the tyre is a very tight fit on a rim (a lot of tubeless rims can have shallow rim beds) I sometimes fit tubeless rim tape as it is thin and stays in place and makes fitting a tyre easier.
Posted : 31/10/2020 3:30 pm
The reasonย  I want to change it is that the tape that came with the WTB wheel is a plastic non-glued one which moves around when I'm fitting a tyre and sort of folds/creases on itself. I mess around straightening it out and getting it back centrally on the rim (it isn't full width tape) and making sure the holes are covered but it doesn't seem a great fit.
Posted : 31/10/2020 3:42 pm
