Rim painting
[Closed] Rim painting
[#3960071]
Anyone had any luck doing this ? And anyone know where you can get replacement Spank rim decals ? Thanks .
Posted : 10/05/2012 9:08 am
Not sure if serious ❓ ❗ ❓
Presuming you are planning on taking the wheel apart to paint? Why not just buy a new rim in the colour you want?
Posted : 10/05/2012 9:21 am
Dulux and a gloss roller?
Posted : 10/05/2012 9:23 am
Ha I know it's an odd question , but the rims are in excellent condition and are expensive Spank Subrosa in brown and i need black to suit my new frame , and if I sell them and buy again I'm sure to loose quite a lot of money , so was mulling this over in my head as a solution .
Posted : 10/05/2012 9:30 am
Now that has to be a euphemism!
Posted : 10/05/2012 9:32 am
Usual principles apply...paint may look ok but won't be durable.
I've had a couple of pairs of rims powder coated and it worked fine.
Posted : 10/05/2012 9:33 am
I guess with the durability aspect powder coating would be an option , thanks I hadn't thought of that route .
Posted : 10/05/2012 9:36 am
Might be easier to paint the frame to match the wheels. And just think of all that extra rotational weight!
Posted : 10/05/2012 9:37 am
strip and polish the rims might be easier.
Posted : 10/05/2012 9:38 am
the issue is getting a hard enough coating on the rim that will with stand some abuse. paint isn't really the right product. It will chip and the old finish will show through, if they have been anodized then paint will not key tp the surface well. Any flex (and wheels need to flex) would crack the paint.
So powder coat is the best option for a refinish, prices will vary, Coats tend to do big batchs of one colour, so if you like the colour he is doing that day just getting the rims done might be dirt cheap (beer money) but if you want ocean otter purple then its going to cost and take time.
you'll need to factor in the costs of wheel builds, the eyelets in the rims will also get coated aswell.
Yes I will look into the powder coating process as I want them done correctly . Thanks guys.
Posted : 10/05/2012 9:47 am
Could the paint baking process weaken the rims?
Posted : 10/05/2012 9:49 am
[i]I want them done correctly[/i]
I'd just bite the bullet and get new rims that are already anodized in the colour you want. Powder coat will be heavier, too.
Posted : 10/05/2012 9:50 am
Not a single innuendo? You guys are slipping.
Is it pink but you want it brown?
Posted : 10/05/2012 10:35 am
What about Steve the anodising bloke?
Posted : 10/05/2012 10:43 am
I had a mavic cross ride wheel (black) which had rim braking surface (silver) on it. Given both my bikes are disc only, I masked the rest of the wheel off and sprayed the braking surface black. Looks ok and you cant really tell unless you look very close.
Posted : 10/05/2012 9:34 pm
