Riding with worn he...
Riding with worn headset bearings
 PJay
I noticed for the first time yesterday that my steering is a tad less 'free' and the bars 'catch' slightly when turning from/through the forward position.
I've probably been riding like this for a while but only recently noticed. Any harm riding a couple more times with the worn bearing whilst the new ones arrive? They're sealed cartridge unit.
Posted : 01/02/2026 11:09 am
I had a pair of headset bearings completely disintegrate when I changed them a few years ago, they were so bad I had to use a screwdriver to chip the outer part out of the cups. There was no damage to anything else but it could well have damaged a frame with an integrated headset where the bearings drop straight into the frameย
Posted : 01/02/2026 11:16 am
Assuming they are intact rotate the entire bearing (inner + outer race) 180 degrees (upper and lower bearings), and that will eake them out until the new ones arrive.
Posted : 01/02/2026 11:25 am
I wouldn't worry. Just go easy on the flip barspins.ย
Posted : 01/02/2026 11:50 am
Shrugs shoulders. Abuse mine, always have done. Bit rusty? Clean them off for tomorrow's ride, regrease and make mental note to change them that week. 6 months later, bit rusty? Etc. etc. for years.ย
Posted : 01/02/2026 1:20 pm
I think it was Mapdec who had a video about the ring of death iirc where the wedge could wear into the steerer tube. There's a possibility of this if the top bearing can't move freely.
Posted : 01/02/2026 2:14 pm
pothead+1
If the bearings either drop into the frame directly (without cups) or drop directly onto the fork crown (without crown race insert) then a sticky bearing could turn and damage something, especially CF
Pop them out, see which is sticking. Pick the seals out with the tip of a pointed blade, flush with WD-40, regrease and pop the seals back and test. That'll probably fix it for another few months if it's not too bad.
Use a short mudguard to protect the lower bearing year roundย
Posted : 01/02/2026 2:21 pm
Normally fine if the bearing is moving but a bit rough. As above - there is a chance of damage if the whole bearing is moving in the frame and it is in direct contact (no headset cups). That scenario is relatively rare though, especially in a headset with the symptoms you describe - that sounds like knacked bearings that still move. I've ridden bikes like that. My commuter probably for a few months.
Posted : 01/02/2026 3:51 pm
 PJay
It's an FSA Orbit MX, so 11/8" external cups. Hopefully the new bearings will be with me in a few days.
Posted : 01/02/2026 3:58 pm
