Reverbs- changing t...
[Closed] Reverbs- changing the post diameter & length possible?
I have a new 31.6 / 380 and an old 30.9 / 420. After striping the 30.9 it looks like I can swap the aluminium lower outer tube off the 30.9 and put it on the 31.6, so I have a nice new reverb which fits.
Is this within the realms off possibility?
The new keys might be exactly the right size but cant see what else wont work.
Posted : 21/01/2014 9:44 am
Cant you just use a QR, WHAT DID YOU DO BEFORE THESE DROPPERS WERE INVENTED? Gggrrrr.
Posted : 21/01/2014 10:14 am
 st
The internet used to say that you could send your post away for a tube swap so I guess so.
What's 31.6mm in French then??
Posted : 21/01/2014 12:04 pm
Its send le wrong size.
Posted : 21/01/2014 12:28 pm
The inner bits are all the same, yes you can change the outer tube ๐Ÿ™‚
Posted : 21/01/2014 1:20 pm
Spoke to one of Locos colleagues, he thinks the IFP will need resetting as the oil level is different between the lengths.
Posted : 21/01/2014 1:23 pm
