Reverb slow to move...
[Closed] Reverb slow to move, will bleed solve it?
Got my reverb serviced by tftuned a little while ago and it's always been on the slow side to move - despite correct air pressure.
Will a bleed help speed it up or would it be oil inside the unit?
Ta
Posted : 18/02/2017 11:36 am
A remote system bleed has solved slow movement for me in the past. And it's easy so you might as well do it if you have the bleed kit.
Posted : 18/02/2017 11:59 am
Also undo the big nut that holds the seal and lube it.
Posted : 18/02/2017 12:56 pm
Check you haven't overtightened your seat clamp. Have you adjusted the dial on the remote lever to adjust speed of return?
Posted : 18/02/2017 1:51 pm
As mentioned a bleed will normally sort, just dont forget to do it in full slow.
Posted : 18/02/2017 4:01 pm
Another one to suggest checking the speed dial. I find a sure fire way of knowing if it needs a bleed is turning to full slow and if it is either very hard to push down or very slow to return it proberbly needs looking at
Posted : 18/02/2017 5:42 pm
ahhhhh i did a bleed at full fast but it still made it better, will doing it at full slow make it even better?
Posted : 19/02/2017 12:32 am
Have a look at the epic bleed solutions web site, there's a good "how to"
I'd suggest just doing the lever for now. Get it parallel with the ground, turn to full slow and screw on the syringe with a bit of oil. If you apply a bit of pressure you should see the lever extend a bit. With pressure on the syringe pump the lever a few times. Turn to full fast and again with pressure on the syringe pump the lever again. Repeat a few times, but finish on slow, put some pressure on the syringe just before you unscrew, release pressure, put grub screw back and test..!
Posted : 19/02/2017 10:01 am
Mine was veeeerry slow this week, was dreading having to bleed it (remembering bleeding Avids back int' day) but it was actually incredibly straight forward.
If you bought the post new, it comes with everything you need, even the torx key.
Posted : 19/02/2017 11:37 am
Yes - the slow setting increases the system volume, meaning less oil moves and so the lock is released 'less' hence its slower. If you bleed on fast you don't put enough oil in the system to ever fully release the lock. Put another way I find bleeding on fast tends to lead to it working like its half slow when fully fast, and not working at all when its on full slow.
Posted : 19/02/2017 11:43 am
