Reverb remote quest...
[Closed] Reverb remote question
[#5425485]
Am picking up a new (to me) frame tomorrow and considering treating myself to a reverb for it. How do most folks fit the remote, above or below the bar?
Seems like it's supposed to go over the top, but that would mean it might get damaged if I ever stood the bike upside down. Not that I'd ever do that of course as I realise how amateur I'd look.
I might go 1x10 so there would be no shifter on the left for the remote to get in the way of, meaning I could mount the remote under the bar. Is this a good idea? And would it mean I'd need to buy a right hand remote?
I'm assuming of course that the reverb is still the most robust dropper post. I did look at the Thomson for about 2 seconds until I saw the price!
Ta
Posted : 14/08/2013 9:30 pm
Rh remote on left hand upside down if it can fit just so its out the way. Personally i prefer the lever on the rh in terms of ergonomics but it is more vulnerable to damage. (Got 2 bikes with each setup)
Posted : 14/08/2013 9:34 pm
LH remote mounted upside down on RH side. Works fine and more convenient too, though it could go closer to the shifter if it wasn't such a stupid shape.
Posted : 14/08/2013 11:28 pm
No idea about the lever, but eh? Is this true - I wondered why the squirrels mocked me when I fixed a puncture?
Posted : 14/08/2013 11:31 pm
bought RH to mount upside down on left (figured that was best as you don't use the left shifter as much). Ended up having to mount it upside down on the right, so RH upside down on RH side.
Posted : 14/08/2013 11:35 pm
Right hand lever mounted under bar on left here. 1x9 so space is ok.
Posted : 14/08/2013 11:37 pm
Just put one on my gf's bike, right hand lever mounted upside down on the left. It really is a stupid shape though, an hour of carefully filing the shifter to get the reverb remote to fit snugly in beside it and it's still not ideal. Ok for my bigger hands but a bit of a stretch for her.
Posted : 15/08/2013 9:25 am
Thanks all.
Think I might pop down to the LBS later today for a natter, price up 1x10 etc. Hopefully they won't see me before I've parked, I'm sure last time they did they put the closed sign up and hid behind the counter.
Posted : 15/08/2013 9:42 am
What? You don't carry a trail bike stand in your camelback?
Posted : 15/08/2013 9:44 am
wtf? how does that work? what finger do you use to press the button?
Posted : 15/08/2013 9:47 am
The seventh one, he's from Sheppey.
Posted : 15/08/2013 9:54 am
Defo mount under the bar, much easier to activate. I have it on the right hand side even though I have 1x10 setup - shop messed up the order, but it works well and leaves my left hand to concentrate on doing skids. takes abit of faffing to get everything in place though.
Posted : 15/08/2013 11:36 am
I found the opposite. I prefer the feel of the one on top of the bars
Posted : 15/08/2013 12:10 pm
same here. Mine is inboard of the shifter/brake which is on an ispec mount. I did see a pic on here the other day of someone with it between the grip and the shifter, which looked neat
Posted : 15/08/2013 12:16 pm
If the shifter gets in the way, thats the one I'd have in the shitty position, ie inboard, as you'll use the brake and reverb way more often. Reverb mounting was the push I needed to go 1x10.
Posted : 15/08/2013 12:24 pm
shifter finger (index finger?), works a treat tbh. brake levers are well in but they're so powerful that one finger braking is ideal. Very very occasionally I've realise I'm fondling the trigger shifter by accident, very rarely tho.
Posted : 15/08/2013 6:35 pm
The LEV is worth a look too. The lever's smaller than the reverb and more crash proof. UK support is back in place but its cheaper to buy from Germany
Posted : 15/08/2013 6:42 pm
 DrP
RH lever, upside down on the LH side...
Works a treat..
DrP
Posted : 15/08/2013 7:10 pm
Mine, RH under left and being 1x10 with compatible MMX stuff, just goes nice and simple.
And yeah I flip the bike over loads. Every ride to put the wheels in. None of this faffing around trying to hook a rear wheel in awkwardly from underneath. I'd need a roadie crew for that 😀
And the occasional trail repair it gets flipped usually too.
Posted : 15/08/2013 7:58 pm
