Can I use my rotors...
[Closed] Can I use my rotors with new XTs?
[#5425469]
I'm about to upgrade to some new XTs, I'm just wondering whether I can use my original rotors on my PItch. Front 203mm and rear 185mm. Am I correct in thinking they don't come with rotors? Cheers
Posted : 14/08/2013 9:27 pm
What type are they? i use Formula rotors with XT's.
Avids seemed to be a bit thicker and didn't work properly.
Posted : 14/08/2013 9:30 pm
Avid Elixirs. I'm not too sure about hose length either! Seems to be quite a bit of choice
Posted : 14/08/2013 9:34 pm
Will you not need 180 etc, so with those rotors the pads will not be touching properly and wear slightly wrong?
Posted : 14/08/2013 9:55 pm
Remove spacers from bolt stack to make fit.
Posted : 14/08/2013 9:57 pm
im running xt brakes on existing avid rotors,only problem i had was i had to loose the wee spacers and the just attached the calipers right on to the rotor adaptors,im 180 f and 170 r....
Posted : 15/08/2013 12:40 pm
XT Rear is a bit tight clearance wise on 160mm Hope floating, Ive got t slightly offset from central to clear the rivets, not had time to doctor the caliper for clearance yet
Posted : 15/08/2013 1:16 pm
