Reverb really tough...
[Closed] Reverb really tough & rough sounding on compression
has anybody had this and resolved it?
Still just within 2 yr warranty......it is really hard to get it down.....and when it goes it sounds very rough sounding like there is no lubrication.....
Posted : 23/01/2016 6:10 pm
When did you have it serviced last?
Posted : 23/01/2016 6:50 pm
It is coming to end of warranty.....but it is the third incarnation......it was new/replaced last in August.....
Posted : 23/01/2016 6:53 pm
Long shot mate, but had similar on a brand new Reverb Stealth had fitted today. Got bike home, dropped the dropper and it only popped halfway back up and feeling rather rough, balls I thought! Bit of t'Internet research later, turns out seat clamp us too tight, slackened it off a touch and boom, sorted!
Posted : 23/01/2016 9:13 pm
Will check that.....but it has worked previously.....and seat post clamp tightness has not been altered.....
Posted : 24/01/2016 12:56 am
Maybe the cold effecting it perhaps?
Posted : 24/01/2016 11:31 am
If it's anything like mine, which judging by the symptoms you describe, it certainly sounds like it, then it's probably in need of a service.
I think it was the lower bushing starting to break down. I can't complain though, 2.5 years old & no service, and mine is one of the supposedly 'unreliable' 30.9 150mm stealth ones.
If it's under warranty still, I would send it back to SRAM & see what they do first.
Posted : 24/01/2016 12:01 pm
cheers - will do!
Posted : 24/01/2016 5:55 pm
Have sent it back to SRAM.......
Posted : 01/02/2016 12:48 pm
Mines hard to push down by hand and feels rough, but when I use my body weight on the saddle it feels ok. Is that how they are supposed to be?
Posted : 01/02/2016 2:43 pm
If you want something to get it through until a proper service at a later date, just undo the top cap nut/bushing, clean it out and put some fresh suspension grease and fluid in there. Always makes mine feel loads better. That, along with checking air pressure and a bleed makes most feel like new, unless they need warranty work/been used for so long that they need a full service.
Posted : 01/02/2016 2:54 pm
Better still get a corporate giant to really their products are sub standard and get a new one posted through....
Win.
Well, until this one breaks and it now out of warranty....
Lose.
Posted : 07/02/2016 12:43 am
