Reverb lever positi...
[Closed] Reverb lever positioning - shifter pod interference
 rogp
This may have been covered before but what is the consensus on positioning the Reverb lever, upside down on the left side of the bar without fouling the shifter range of movement?
For me, moving the shifter further inboard makes shifting impractical.
If it makes a difference the shifter is an SLX unit.
Posted : 20/06/2012 8:28 am
Mine's inverted, left hand bar, inboard of (closer to the stem) the shifter and doesn't interfere with anything. I don't see any good reason to mount it between the shifter and grip, if that's what you've done?
Posted : 20/06/2012 8:41 am
What brake lever? Grip, shifter, reverb, hope tech lever works for the wife.
Posted : 20/06/2012 8:44 am
Posted : 20/06/2012 8:53 am
 rogp
Yup all the butted against the grip. More for comfort than anything else. I take your point though.
Onzadog - Formula One levers.....
Posted : 20/06/2012 8:56 am
 rogp
Messiah - it was actually your pic that inspired me to experiment but I'd forgotten that you'd run it Reverb --> Shifter --> brake. I will have to try that.
Posted : 20/06/2012 8:59 am
