Reverb hose connect...
Reverb hose connector
2 Users
I'm about to install a new reverb on a Bronson, so internal routing. I seem to have mislaid the red connector tool and everyone is out of stock, so can I just use a small screw and hope for the best? I assume I'll be trimming the hose so no need to worry about knackering that - but will measure twice first!
Thanks
Posted : 24/04/2023 10:51 am
If you just want something to seal the end (rather than something to connect to to pull it through) you can just screw a barb part of the way in.
Posted : 24/04/2023 10:54 am
I plan to unscrew from the post end, seal and push through the frame from the lever end. It's just one grommet at the lever end then up through the seat tube.
Posted : 24/04/2023 10:56 am
