Reverb bleed and qu...
[Closed] Reverb bleed and questions
 mrl
I have a brand new reverb which I have shortened the hose on and the bleed the system. However despite bleeding as instructions 4 times I don't think it is working properly.
There is no obvious difference between the fast and slow settings. Both are slow compared to the ks lev I have on another bike. Additionally I need to push the button in a long way and have to maintain quite a lot of pressure. The pressure is set to 250 psi.
Any ideas other than keep bleeding until it works? When I create a vacuum at the actuator end, pulling up on the syringe, this causes the button to pull in. Does this mean there is still air in the system? If so how do I get it out?
Posted : 17/05/2016 1:08 pm
was it working before you cut the hose? If so then you cant be bleeding it right, you must be missing something. Have a look at the Rockshox videos on you tube. I found the bleed procedure of the reverbs very easy
Posted : 17/05/2016 1:19 pm
before bleeding make sure you have the remote speed adjuster turned fully as per the instructions. I think it's to the fully slow setting.
Posted : 17/05/2016 1:24 pm
or follow the instructions on epic bleed solutions website. They're very good and worked a treat for me. Dont pull up on actuator end syringe too much, as I think that introduces air into the system. I concentrated on pushing on the opposite end syringe whilst not trying to pull too much. Also when you're finishing the actuator bleed make sure you push the syringe in with the speed controller set to the slowest position as I think that gives the maximum volume of oil in the system
Posted : 17/05/2016 1:28 pm
 mrl
Thanks for the replies. I did not try it before I cut! Did he bleed with the speed at slow as instructions . Will take a look at the epic site. The bleed seems very easy and I cannot see what I am doing wrong. Really wish I had tested it before I cut!
Posted : 17/05/2016 2:34 pm
I wouldn't worry. It sounds exactly how mine was behaving until I bled it yesterday using the epic instructions. Follow the epic instructions to the letter and I bet it'll fix it.
Posted : 17/05/2016 2:36 pm
Have you pumped air into the post itself?
Bleed as per rockshox / sram video on YouTube, slowest setting for remote , and check the bolt is tight where the hose goes into the post , as sometimes that is loose and can leak oil/ let in air
Edit sorry you have set the pressure
Posted : 17/05/2016 3:21 pm
 mrl
Followed the epic bleed instructions twice, no difference. Went back to the sram instructions and tried again. No luck. The speed dial actually slows it dow which is really odd. Any other suggestions before it gets posted offie a warranty inspection?
Posted : 23/05/2016 9:14 pm
When I create a vacuum at the actuator end, pulling up on the syringe, this causes the button to pull in. Does this mean there is still air in the system?...
No.
Just before disconnecting the last syringe, push it down to get as much oil into the remote as possible and force the button out as far as it will go.
The button has quite a long travel.
Are you turning it the right way? (There is an arrow engraved on it showing fast/slow directions)
Posted : 23/05/2016 11:01 pm
Had similar issues with mine. Didn't matter which way adjuster was turned or whether the button was above or below the seat post.
Not sure which end you cut it but mine i had to route part through to tube and turned out the barb at the seatpost had a tiny weep. Would hold for about 1 ride but then the return would slow down gradually and stop working.
I'd suggest a new barb or, at handlebar end, recut 3cm off the hose and screw back in keeping a firm pressure on the trigger whilst it cuts the thread into the hose.
Posted : 24/05/2016 7:19 am
