Reverb and steel fr...
[Closed] Reverb and steel frame
[#7244277]
Having in the past spent a good fortnight drip feeding plus gas into a stuck Ali seatpost steel frame combo are there any issues with reverbs similarly getting stuck.
Should I be taking it out and cleaning it every month or so?
Don't want it to get stuck, if (when) it breaks!
Posted : 04/08/2015 11:59 am
I used some copper slip on mine when installing. I still have the quick release lever on it, so occasionally, I just undo the lever, and give it a twist in the seat tube. No need to remove and clean.
Posted : 04/08/2015 12:03 pm
No issues with mine in 3 years, used carbon paste on assembly and move it occasionally to make sure it doesn't seize.
Posted : 04/08/2015 12:28 pm
No issues with mine so far, but I'm only seven months it and it does come out from time to time to check the pressure.
Posted : 04/08/2015 12:39 pm
slight hijack before replicating thread, but what should be used with alloy post in titanium frame?
I'm guessing nothing needs to be applied to titanium bars in alloy stem?
TIA 🙂
Posted : 04/08/2015 12:45 pm
Same here!
Posted : 04/08/2015 12:48 pm
The problem you'll have with alloy components in a ti frame is they get eroded away by electrolysis. Lots of Ti-prep is the solution.
Seems a lot of effort to go to when you could have just bought a Kona Process off the shelf half price.
Posted : 04/08/2015 1:32 pm
Ti prep, yes that was the type I was racking my brains over.
ta.
Posted : 04/08/2015 1:40 pm
+1
Posted : 04/08/2015 2:04 pm
Carbon paste in a steel bike, to act as a slight barrier??
Posted : 04/08/2015 3:49 pm
You need the carbon paste to stop the reverb slipping without needing excessive clamping force, carbon paste is just grease (of a type that won't attack and weaken the 'plastic') with grit in it to provide friction.
Posted : 04/08/2015 6:11 pm
