OK, so - left it way too long to change my chain and it appears now I'm paying the price; new cassette required as you'd expect, but having major problems with chain suck and general shifting up front - and on inspection, looks as though chain rings need replacement as well....
.... have searched high and low and can't find direct replacements for my 2x10 chain rings (39/26), so appears my only option is a new chainset and at 250 of my finest English pounds.... I'm not massively enthusiastic about that.
Appears a complete Shimano 2x10 XT chainset can be had at a pretty good price in comparison; but am wondering whether there may be any sort of problem/compatibility issue running an XT chainset with everything else is SRAM X0.
Any guidance?
Cheers!
It will be fine.
Try these. [url= http://http://www.ukbikestore.co.uk/product/54/crtxb/truvativ-alu-blast-black-2x10-chainrings.html ]Truvativ chainrings[/url]
Not cheap for the big ring, but they are the ones you need.
I put the big one on my X0 chainset recently. Chain suck is often caused by worn front rings, and is worse with a new chain.
Order in from UKbikestore.... Cheers!
