Replacement Cree XP...
[Closed] Replacement Cree XPG pcb needed for Trout light, any ideas??
Hi,
One of the LED's on my Trout light has packed in and needs replacing. I've found a few places that sell just the LED but the ones in the light came mounted on their own pcb and knowing what to do with just the LED is a bit beyond my skill or interest level.
So does anyone know where I can buy a pcb mounted Cree XPG like Troutie used???
(I've sent him several emails but not had a reply so guess he's no longer in the light business)
Thanks
Posted : 12/11/2014 7:00 pm
What size PCB?
Posted : 12/11/2014 7:59 pm
10mm square
Posted : 12/11/2014 9:35 pm
Stick a pic up. As far as I'm aware most of his lights use a driver pcb with LED's on normal boards. If I can see it I might be able to help..
Posted : 12/11/2014 10:40 pm
Thanks
Posted : 12/11/2014 11:11 pm
[url= http://www.cutter.com.au/proddetail.php?prod=cut1364 ]THIS[/url] I suspect.
Posted : 13/11/2014 12:05 am
This will be what Chris used.. The other cutter link is the XP-G2..
http://www.cutter.com.au/proddetail.php?prod=cut1032
I might have some xp-g's at home, but I know I don't have 10mm square PCB. Might have round.
Posted : 13/11/2014 8:52 am
The cutter ones linked will do the job. Shipping is quite expensive from them for 1 LED tho. If GD doesn't have any this should do the job: http://www.amazon.co.uk/Cree-480lm-White-Light-Emitter/dp/B00CBTM6FA
Posted : 13/11/2014 9:06 am
Thanks very much guys that's a great help.
The round one should be fine shouldn't it as its the same width and can be soldered in line just like the square ones?
GD if you've got one then great but I don't mind getting the amazon ones.
thanks again
Posted : 13/11/2014 11:02 am
Yep, round one would be fine. Just need to solder across the pads. Should be +ve on one to -ve on it's neighbour..
Posted : 13/11/2014 11:09 am
 DeeW
Round should be fine but square would be better as the legs of the optics sit on the corners of the square boards. Sure YOU will be able to bodge something though ๐Ÿ˜‰
Posted : 13/11/2014 3:41 pm
