Hello,
I've been helping a neighbour with his his bike.. he has a v basic bike from the equivalent of halfords here...
He has a square taper BB which was goosed..he replaced it with a shimano cartridge unit (same dimensions exatcly) and now the chainline is shot..
i dont understand i must admit - never had that happen..?
What do you think?
How did you measure the BB, that was "goosed"?
The length of the spindle/axle doesn't always equate to the stated size of a BB. Found this with Shimano BB's.
there are also at least 2 "standards" for the dimensions of the taper, maybe he/you got unlucky if the previous one wasn't shimano
Not an "E" type is it?
If the old BB/crank was ISO and replaced with a JIS of similar dimensions, the 'fatter' taper of the JIS BB would push the crank/chainline 4.5mm out.
ah ok, many variables.
I measured the length of the spindle on the one that was going out, as i have always done.. then measured the frame and thought it'd be good...
its not an old bike, just a cheapo one.
Going to have a remesure and see.
The size should be marked on the old BB.
yes thanks it was but we measured just incase! Its a cheapo bike and was semi printed on the bb.. but not v clear.
in all my years of mtbing and biking in general ive never had this issue..
sorted it now. all is good. ta singletrack
what was wrong ?
