Could do with swapping headsets around frames - too tight to buy another one at the moment. Going back to HT from FS for winter & then back again in the spring. Frames are 2nd hand so they've had at least two headsets inserted already (original owner + one HT->FS move by me).
Removal of headset is via a pukka headset removal tool & reinsertion using a pukka headset press (if any of that makes a difference).
Does repetitive headset removal/insertion stress the headtube & should therefore be kept to a minimum?
or am I worrying about nothing...
Posted : 13/10/2013 10:48 am
Nope, do it with the proper kit and you're fine - more likely to damage the cups than the frame.
Posted : 13/10/2013 10:49 am
