Removing Rockshox l...
[Closed] Removing Rockshox lower
2010 U turn reba's turned the bike upside down released the air and removed the the nut and tapped in the rod also removed the allen bolt from the other side. I expected the lowers to slide away as per the Fox forks but there still fixed.
Do I have to remove the controls and caps from the top of the forks?
Posted : 03/04/2012 12:26 pm
- no
did you tap the bolt to free the rod on the other side as well?
Posted : 03/04/2012 12:30 pm
No I just assumed that as it didn't protrude through the lower leg it wasn't going to be a issue but if thats whyit appears stuck then I will give it a go.
Posted : 03/04/2012 12:38 pm
yeah, the pushrod is a friction fit on that side too, undo bolt a few thread, wallop it to release the pushrod, remove bolt and then they should just slide off
Posted : 03/04/2012 12:39 pm
What amedias said.
Don't forget to remove the air from the negative chamber as well as the positive, or you might get a surprise.
Posted : 03/04/2012 12:46 pm
Nice 1 ameias also have depressed both schraider valve to release air. All I was doing was a quick seal wipe clean etc on the lowers only ever done to Fox forks before.
Appreciate it chaps ๐Ÿ™‚
Posted : 03/04/2012 1:05 pm
Hey Tony, how did the service go ?
I'm interested to know because I reckoned my RS could be done upside down like Fox forks but haven't yet tried it.
Posted : 03/04/2012 2:15 pm
steel4real - RS are pretty much the same process as fox for a lower leg remove/clean/service
done them upside down plenty of times
Posted : 03/04/2012 3:16 pm
Cheers amedias I think I will give it a go then ๐Ÿ™‚
Posted : 04/04/2012 7:42 am
